I have a mitsubishi software programme in PCD file format and wanted to open the programme with GX Developer but couldnt open.
Any one with an idea, help please
On Thursday, June 30, 2016 at 1:55 PM, Gambit said:
A PCD is a GX IEC Developer backup file. You can't open this with GX Developer.
You will need to get GX IEC Developer
ok but what is the difference between the IEC developer and the GX developer
With IEC Developer you can program via the IEC standard (europe).
GX Developer is standard programming.
Both these packages have been integrated into one GX Woks 2
Many thanks, but currently i have GX works 2 also but cannot find IEC developer, i found GX developer instead please what could be the problem since you said both are integrated in the GX works 2
You will only be able to open a GX IEC Developer project in GX Works if it is for an System Q. If it's an old A series you will have to use GX IEC Developer
