Ethernet cable is faulty
Melsec communication driver is not installed on the GOT
GOT communication settings are incorrect
QJ71E71 is not configured correctly as described in manual
IP address of GOT is exactly the same as PLC +1 (or +2 or any other number) if there is nothing else on the network. If there are other devices on the network make sure the GOT has a different IP address to all of them and is not using the same port as anything else
