Del Posted July 8, 2016 Report Posted July 8, 2016 I used to use the Old Dos based MEDOC very many, many, years. I havn,t programmed for years now. We have GX Works 2 at work, and I am practicing programming an FX 3G - 40M to try and keep my hand in. Allthough I can write and read the program ok, the PLC keeps saying that it has no memory for the comments. Apparently the memory has to be set on the PLC. Any advice or information links will be appreciated Quote
Gambit Posted July 8, 2016 Report Posted July 8, 2016 Did you set up some Comment capacity in the PLC parameters? Quote
Akahige Posted July 8, 2016 Report Posted July 8, 2016 Each block added will allow 50 points of comments available for the program. Quote
Del Posted July 8, 2016 Author Report Posted July 8, 2016 Many thanks chaps I will give this a go on Monday. What a cracking site this is, glad I joinedup 1 Quote
