Do you currently have access to Siemens Step7 or TIA Portal software? If so, write some ladder logic and then switch view to STL. Write several  rungs (networks) of logic. Study the conversion. Then write several networks in STL. Switch the view back to LDR. Did all the networks convert? Did they convert as expected?
I've been asking my Siemens rep for years for a basic ST class and he won't set one up.  I'm assuming because he doesn't know it either.
I've had some luck with the method pop29648 suggested.  Coming from a ladder background, i've found its mostly useful for indirect offset data transfers and canned FC's that are simple math or looping.
Good Luck.
