Rocinante8 Posted July 12, 2016 Report Posted July 12, 2016 I'm trying to read the accel/decel values from the watch window in GX Works (actually I'm trying to read them from my computer code but if it works in the watch window it should work in my code). I can set the values such as MOVP K500 U0C\G142 in the program, but how do I determine the device type (X, Y, D, etc.) and the address. Thanks, Jeff Quote
Rocinante8 Posted July 25, 2016 Author Report Posted July 25, 2016 Turns out the values are memory addresses so there's another command to read/write. All good now. Quote
