Guest Deniz Posted November 24, 2004 Report Posted November 24, 2004 I want to control a drive by using profibus connection. how can i obtain which driver parameter i should use in DB and how to read and and send (exchange) data with it. i have gsd file of the drive but i couldnt find which parameter should be assigned for communicatin. Drive is sew brand. plc is s7/300. Quote
Guest foribeiro Posted November 24, 2004 Report Posted November 24, 2004 Is it a Sew Movimot drive? If yes i have the manual and the commands are very easy, just start/stop, frequency, ramp value and current consumption. Quote
Guest Guest Posted November 24, 2004 Report Posted November 24, 2004 yes it is. But i also need more info for siemens 6ra24 Quote
