Thank you. I did this. Is there an easier way of doing it. On AB you can just go to monitor tags and will show every tag. Does Mitsubishi have an option like that?
I'm more a GX IEC Developer guy that recently started working with GX Works 3, so I more or less jumped over GX Works 2.
Pretty sure there are some guys at the forum with good knowledge about GX Works 2.
Why don't you just monitor the Field where the FB has been programmed and press F# or Online => monitor > Monitor Mode.
If you want to have it in a seperate monitoring window then open a watch windows select the FB from the program and right mouse click registers to watch
Edited by Gambit
