Robo Posted August 23, 2016 Report Posted August 23, 2016 Can anyone point me in the direction to get a GXworks2 ethernet connection to a QJ71E71-100 module mounted with a Q03UD CPU. I have 3 HMI's connected thru a hub and all talking OK, but the PC (Windows7) refuses to connect. I can ping the module (192.168.0.10). I have tried the Mitsubishi PLC connection guide to no avail. Quote
Gambit Posted August 23, 2016 Report Posted August 23, 2016 (edited) Good day Mate.... Most likely you haven't setup up the network number and station number correctly. Check your QJ71E71 parameter setting. Most likely this is setup as network 1 and station 1. This is fine but then in your transfer setup setup the same network number but a different station number for you PC. On PC Side you should have Network number 1 Station No 60 (anything but 1) Ethernet module Network Number 1 station number 1 (The same as setup in your network parameters) Edited August 23, 2016 by Gambit Quote
Robo Posted August 23, 2016 Author Report Posted August 23, 2016 You were spot on. Always the simple answer. Thanks very much. I don't understand why others here missed this as well. My sanity has been restored. Quote
