Hello Dears,
I am trying to write a program in structured ladder. However, the timer will be adjusted by the user via HMI. I have no idea how to address this in  GX works 2 Structure, as it my first structure program. I also have no idea how to assign the time value i.e. seconds, minutes or hours in this case.
Thank you in advanced.
I would suggest Timer100FB but and use decimal values but if you want to use a TIME input then you need TON or TOFF.
I would handle to conversion in the HMI or program
  • Like 1
You should be able to use an integer input and a command in the PLC to convert it from say seconds to data type TIME.  Many HMI products cannot display or edit data type TIME yet.
