TigerLily Posted August 30, 2016 Report Posted August 30, 2016 (edited) I READ IN THE MANUAL FOR THE CJ2M-CPU34 THAT IT IS POSSIBLE TO CHANGE THE IP ADDRESS BY WRITING TO D30098 AND D30099 (MY DEVICE IS UNIT 0). I TRIED TO DO THIS ON A TEST PLC BUT AM NOT HAVING ANY LUCK... I WROTE MY IP ADDRESS #C0A8 TO D30098 AND #0E30 TO D30099 (IP ADDRESS 192.168.14.48) WITH THE CPU IN PROGRAM MODE, I SET THE RESET BIT (A501.00) TO TURN ON ON THE TRAILING EDGE OF THE FIRST SCAN BIT, I CAN TELL THE CARD RESETS BECAUSE I AM CONNECTED VIA ETHERNET AND I GET DISCONNECTED, BUT THE IP ADDRESS DOES NOT CHANGE. IS THERE ANY WAY TO CHANGE THE IP ADDRESS WITHOUT CX-PROGRAMMER? I NEED TO GET A SOLUTION TO MY CUSTOMER TONIGHT AND MY SUPERVISORS DO NOT WANT TO RELEASE OUR DEVELOPMENT CODE TO THE END USER. THANK YOU!!! Edited August 31, 2016 by TigerLily I typed the wrong D memory address
TigerLily Posted August 31, 2016 Author Report Posted August 31, 2016 They do not have the CX-One or CX-Programmer software, is there a separate utility just for the IO table that we can provide them? I am in NY and they are in CA...
Jay Anthony Posted August 31, 2016 Report Posted August 31, 2016 I think the IP address is changing, but you need to change your PC IP address to something on the same subnet. Such as 192.168.14.xxx
Sergei Troizky Posted August 31, 2016 Report Posted August 31, 2016 Just changing the port IP address may be not enough. Is there Ethernet/IP network? If yes, it must be reconfigured as well. HMI? It must be reprogrammed for the PLC new address. Also, the new address may need to be reflected in the IP Address Table for Fins/UDP.
innoaloe Posted July 30, 2017 Report Posted July 30, 2017 (edited) From Manual W465 : So basically, if the original programmer uses IO Table to set the PLC IP Address, you cannot change the IP Address via DM area anymore. DM Area can only be used to change IP Address if the inside the IO Table IP Address is set to 0.0.0.0. The thing is you are able to change their DM Area, so CX-Programmer is there right? Or are you using FINS communication tools like Multiway? If Multiway is the case, no luck then... EDIT : Just realized this post was old after I replied ლ(´ڡ`ლ) Edited July 30, 2017 by innoaloe LOL
