emman Posted September 7, 2016 Report Posted September 7, 2016 Hi guys have a good day, can you help me about my melsec plc? i have my mitsubishi melsec fx 1n plc and communication cable what do i need to make the programming, what kind of program or sofware do i need? thanks a lot. Quote
Rodney Posted September 7, 2016 Report Posted September 7, 2016 You require G X Developer to programme your P.L.C. Rodney Quote
colandra Posted September 7, 2016 Report Posted September 7, 2016 Hello, You need either a SC00 cable or a SC09 cable or a FX-USB-AW cable. Any of these will work with the FX1N PLC. As for software you have several choices. You can use GX Developer, or GX Works 2, GX Works 3 will work as well, because it has GX Works 2 and Gx Developer included in the GX Works 3 package. There is also the original dos based software which is Medoc. This is long dis-banded now, you would need one of the last versions of Medoc produced which did support the FX1N. All these options I have provided will achieve what you need. Regards Colandra Quote
emman Posted September 8, 2016 Author Report Posted September 8, 2016 Thank you very much rodney and colandra i will try to find now the GX Developer. thank you for your help guys. more power Quote
