Hello,
I am using an NJ301 PLC with an NA series HMI. I am communicating to the PLC via FINS protocol using the DotNet FINS UDP application by Jay Anthony found under the downloads section.
I am finding that when I write a string to an address, the bytes order are reversed. For example,  I am writing the string 'Test' to variable 'FINS_String', which is a String data type at memory address D20. My FINS command is the following:
010282001400000254657374
0102: Write
82: Data Memory
001400: Address 20
0002: Write 2 words
54: T
65: e
73: s
74: t
The value that appears on the HMI and in the watch window is 'eTts'. If I write 65547473 (eTts) as my command, it appears correctly as 'Test' on my HMI.
I debugged the application and I see that the byte array is being sent in the correct order, so I'm not sure what the matter is. I can't imagine that to pass a string through FINS protocol the hex values need to be switched every time.
Any help would be appreciated. Thank you for your time.
Hello,
From what I recall the order is "Test". I do know other PLCS are low-high byte when using words for characters. For FINS we support:
Format Description
0) Default
1) 2 characters per word, character order high, low – default ABCD
2) 2 characters per word, character order low, high BADC
3) 1 character per word, character in high byte
4) 1 character per word, character in low byte
5) 4 characters per longword, character order ABCD
6) 4 characters per longword, character order DCBA
Are you looking at the memory in the PLC or on the HMI?
Edited by Mark-
1 hour ago, gunnaraherman said:
I'm rather new to PLC's and was unaware of it.
It is not a PLC issue. It is a CPU and/or protocol issue. Years ago a colleague and I were working on a project that included communications between two devices. The CPUs were from different manufactures (Motorola and Intel). His was low-high, mine was high-low. Several years later, the another collaboration only his was high-low, mine was low-high.
