sasha Posted September 12, 2016 Report Posted September 12, 2016 Developed new software for the controller OMRON - OMRON_Communication. Program OMRON_Communication designed to exchange information between your Android smartphone and controllers of the family OMRON(CS1,CJ1,CJ2,CP1H,CP1L...). Information is exchanged by means of the computer and router, which is connected via Wi-Fi network with your smartphone and interface Ethernet (Ethernet/IP) (RS232) to controller. The smartphone has the following funtion : - modes read/write of the memory controllers DM,W,CIO,EM,HR; - cyclic reading of the memory areas; - the formation of Alarms in the event of a controller failure; - read the contents of the directory computer; - reading contents of a text file computer; etc. The program OMRON_Communication consists of 3 parts: - OMRON_WI_FI_Connection.apk - is implemented on the smartphone - setting and monitoring of parameters and variables on the smartphone for information from the controller; - Server_Send_Receive.exe - implemented on the computer - intermediate server computer; - Server_Controller.exe - implemented on the same computer, the server computer for sharing information OMRON controller; 2. IMPORTANT !!! The smartphone communicates with the router via Wi-Fi network. Wi-Fi router can be connected to local or WAN networks. Obviously, the router must be properly configured by the system administrator. It is also obvious that the smartphone and the router must belong to the same Wi-Fi network. 3. Work application Server_Send_Receive.exe and Server_Controller.exe tested on computers running the operating systems Windows XP and Windows 7. Work application OMRON_WI_FI_Connection.apk was tested on smartphones Samsung, Philips running the operating system Android 5.0, Android 6.0.It is better to use a smartphone with a diagonal of 5 inches and above. 4. Application OMRON_Communication paid, the cost per one user is $5 USA. Distributed through Google Play. Application OMRON_WI_FI_Connection.apk must be install in internal memory smartphone, not in SD card !!! 5. OMRON_Communication have detailed Russian/English manual. Address for download full manual - https://yadi.sk/d/TYRm_SE7utJnk . Address for video example (poor quality) - https://yadi.sk/i/6UP7m1NZuvwWG Address for download Server_Send_Receive.exe and Server_Controller.exe is on screen OMRON_WI_FI_Connection.apk; Enjoy. ab.ryss@yandex.ru Quote
pfort Posted September 12, 2016 Report Posted September 12, 2016 (edited) I don't find it on Google Play. Edit: OK, found it now... Edited September 12, 2016 by pfort Quote
