johnson pay Posted September 15, 2016 Report Posted September 15, 2016 Hi all, I'm using FX5U PLC, then using Ethernet TCP to received data from other instrument device, after received the data is ASCII code e.g 2.8934E+0, now I want to send this data through modbus RTU, e.g 40001 = 2. 40002 = 89 40003 = 34 40004 = E+ I have doing some conversion but still get decimal code, anybody have do it before, I try a lot of method to convert the data, but still cannot Quote
Gambit Posted September 16, 2016 Report Posted September 16, 2016 You should be using real values and instructions. E*, E+ etc Quote
kaare_t Posted October 6, 2016 Report Posted October 6, 2016 Not sure if I got this right: You want to send the "characters" as ASCII over a binary line (RTU)? You don't want to send the data as regular binary float/real values? Quote
