Hi guys,
currently working on the communication with videojet 1620 printer (Continuous Inkjet Marking), in there operators manual (http://www.videojet.com/content/dam/Countries/North%20America/Operator-Manuals/CIJ/1620-Operator-Manual.pdf)  the say :
- How to Configure Ethernet Port
Refer to WSI/ESI Communications Protocol addendum for more
information.
But cant find this addendum anywhere in the web, all i did found is this pdf attached "Videojet 1510 and 1210 Simple Communications Protocol".
I'have try it with th eprinter using the Ethernet port and all i can find open is the FTP(21), 3000, 3001 and VNC(5900). An d i have send same packets from the WSI/ESI to the print via 3000 and 3001 with Packet Sender but the response was empty!!
is there any one that know this protocol ESI/WSI or did work with this printer or simillar ?
i found this info in the FTP folder :
<?xml version="1.0" encoding="utf-8"?>
<CONTROLLER_INFORMATION>
    <START_DATE date="07/09/2016"/>
    <HARDWARE BoardType="CSB4"/>
    <VERSIONS>
        <WINDOWS_CE Eboot="4.0.3" CE_Image="2.0.9"/>
        <SOFTWARE Type="Excel" Version="1.0.423.0" SVN_Build="28116M"/>
    </VERSIONS>
</CONTROLLER_INFORMATION>
180020947-Videojet-WSI-Protocol.pdf
On 9/16/2016 at 3:43 AM, yacineamk said:
Was having the same problem, for the protocol, write to me gmkariz@gmail.com
Hi guys,
information.
    <VERSIONS>
    </VERSIONS>
