Hello Everyone,
I am very new to the Mitsubishi PLC world and having a hard time communicating FX3U-ENET-ADP to Ifix SCADA VIA IGS (Kepware) driver.
I am using GXWORX2, and am not sure what settings to insert into the Ethernet settings of the module.
1. Should it be Melsoft Connection, MC Protocol, or data monitoring?
2. Should I be using UDP or TCP?
I have tried Melsoft using 5556 as the port number, but to no avail. I have tried data monitoring briefly, and MC Protocol without assigning any port no and destination IP address.
Mitsubishi Tech recommended me to use MC Protocol.
What are you guys doing to make it happen?
Thanks in advance for the help.
Edited by nayil100
typo
Thanks for the response. I was able to resolve the issue after numerous failed attempts.
I basically used MC Protocol with TCP/IP and assigned it to port 5001 in the PLC.
On Kepware/IGS driver side, I entered the IP address followed by the device ID (XXX.XXX.XXX.XXX: Device ID). I selected Mitsubishi Ethernet driver option and tried using Device ID of 0,1 and 2 and none of those worked. I finally decided to try the last allowed Device ID of 255 and lo and behold it started communicating.
Edited by nayil100
Hi @nayil100, can you tell me
1. What PLC you used to connect to Kepware?
2. What Kepware version you used?
3. What GX Works2 version you used to set FX3U-ENET-ADP protocol and port?
4. Did you use FX-Configurator-EN ?
I have a hard time connecting FX3G + FX3U-ENET-ADP to Kepware v6.xx.
I already a procedure from Kepware manual, but still no luck.  I used format IP address XXX.XXX.XXX.XXX:255, TCP protocol and port 5001.
Thanks in advance
Edited by kusumy
