shehoxs Posted December 1, 2004 Report Posted December 1, 2004 My problem is Under Dos if I use laptop toshiba pentium 233MMX i can't conect PC to PLc (com port eror), but if i use desk top Pentium3 comunication PC to PLC ok but if i use desk top. I am use Medoc Dos Software Adapter SC03 CpU PLC A0j2 Help me I need IB(NA)-66057 Programming Manual 13J751 English and IB(NA)-66058 13J601 User's Manual Please help me Thanks Your Attention Best regard yossy Quote
panic mode Posted December 1, 2004 Report Posted December 1, 2004 http://www.meau.com/Files/IB_NA_66057-C.PDF Quote
panic mode Posted December 6, 2004 Report Posted December 6, 2004 some people have problems browsing Mitsubishi website but i can't help with that. it looks like they forward you to the server that is geographically closer to you. if navigating to www.meau.com, clicking on download and then manuals doesn't get you to the right page, you might try to get there directly: http://www.meau.com/eprise/main/sites/publ...Manuals/default or try alternative server like the one in Germany: http://www.mitsubishi-automation.de/ let us know if this helps, if not we might simply post the file you are looking for. actually give me a minute, I will try to add both files for you into download section in this forum... Quote
panic mode Posted December 6, 2004 Report Posted December 6, 2004 done... http://forums.mrplc.com/index.php?act=Downl...&CODE=01&cat=20 Quote
Guest Albert Fanakapan Posted December 6, 2004 Report Posted December 6, 2004 For any manuals or documents - the complete range including 'white papers' and suppliments to manuals I go direct to the knowlegde base. here http://194.130.244.129/sourceandselect/app...n/LogonForm.asp This is the login page - you have to register 1st but its free and than you have everything Mitsubishi at hand Quote
