My.taj Posted October 5, 2016 Report Posted October 5, 2016 Hello. I'm try to connect use serial port in pc but no any responses. Is cn22 requir drivers?
Crossbow Posted October 5, 2016 Report Posted October 5, 2016 What is CN22? There are numerous posts here if you search to show the proper wiring for the serial cable. 1
innoaloe Posted October 5, 2016 Report Posted October 5, 2016 Guess it should be either USB-CN226 or CS1W-CN226 cable since the PLC is CJ1M-CPU13. If you are using USB-CN226, indeed you'll need the driver which included as a CD-ROM when you buy the cable. If you are using CS1W-CN226 directly plugged to DB9 serial port in PC, no driver will be required. But if you are using additional Serial-to-USB Converter, of course a driver will be required for that converter Whichever cable you are using, make sure the DIP Switch for Peripheral Port is set to Off 1
My.taj Posted October 5, 2016 Author Report Posted October 5, 2016 Thankyou for help I'm use cn22cable with usb. Rs232 converter I'm found problem about cx.programmer not installed in right way
