morens Posted October 11, 2016 Report Posted October 11, 2016 Hello im on a project using this new FX5 plc , with a FX5-40SSC-S module to control 1 axis (MRJ3B motor). I could make the motor Jog and change speed. but i cant perform the position control. A tech guy told me that i must pass for zero in order so i can make a home return postion (i choose the software method). but nothing. Th HPR request flag its still "On". does any one have work with this equipments? thanks for your advices. best regards
Luke.S Posted October 12, 2016 Report Posted October 12, 2016 By the software method, do you mean the "Data set method"? I guess that your equipment does not have a "near point DOG" limit switch if you are using this option.
Gambit Posted October 12, 2016 Report Posted October 12, 2016 (edited) IF you want to you can disable must pass through z phase. But if you make a full rotation with jogging before making Home position return this won't be an issue. Have you checked out the E-learning on the Mitsubishi Site for the 40SSC All:http://www.mitsubishielectric.com/fa/assist/e-learning/eng.html FX5-40SSChttp://www.mitsubishielectric.com/fa/assist/e-learning/dl/eng/4-SIMPLE_MOTION_Module_iQ-F_na_eng.zip FX5-40SSC(PDF version)http://www.mitsubishielectric.com/fa/assist/e-learning/pdf/eng/4-SIMPLE_MOTION_Module_iQ-F_na_eng.pdf Edited October 12, 2016 by Gambit
