Guest CLToh Posted December 2, 2004 Report Posted December 2, 2004 Hi all, Recently just start using Siemens, now need to draw some panel layout, can someboby kindly provide a link or website whice can download the siemens components drawing in CAD format? Thank you. Regards, Toh Quote
guillencito Posted December 2, 2004 Report Posted December 2, 2004 This is the file I have for S7-200 If you want drawings about other models, or you like this drawings in the original .dwg format, this is the page where I downloaded it: http://www4.ad.siemens.de/-snm-0135109872-...&objid=10860557 AutoCAD_pdf.zip Quote
Crossbow Posted December 2, 2004 Report Posted December 2, 2004 All Siemens CAD drawings are available on the web. I would go to www.sea.siemens.com (the Energy And Automation Group) and search for them. There's also a nice support site whose address I have at work, will forward in later... Quote
cltoh77 Posted December 7, 2004 Report Posted December 7, 2004 Hi, Thank you for your help. I had download the CAD drawing I need. And a lot of info can be found inside too..... regards Quote
Crossbow Posted December 9, 2004 Report Posted December 9, 2004 The good technical downloads website for Siemens is: www4.ad.siemens.de Quote
