christophertedjo Posted November 3, 2016 Report Posted November 3, 2016 i need a example code for position control of MR-J3-20A with QD75D4 as intelligence module. and i want to see the parameter if possible
AlexMota Posted November 3, 2016 Report Posted November 3, 2016 (edited) Hi, Which software are you using? GX developer or GX Works2? If you are using GX Works, you can set up QD75D4 adding as a new module in intelligent function Module. And you will need to write a code just for movement. Edited November 3, 2016 by AlexMota
christophertedjo Posted November 4, 2016 Author Report Posted November 4, 2016 14 hours ago, AlexMota said: Hi, Which software are you using? GX developer or GX Works2? If you are using GX Works, you can set up QD75D4 adding as a new module in intelligent function Module. And you will need to write a code just for movement. hello. im have both software, but im currently using GX works2. i need a example code for movement. i am very new to PLC. i havent work with any plc yet. and is very hard to find free tutorial for this QD75d4 what kind of code do i need?
AlexMota Posted November 4, 2016 Report Posted November 4, 2016 i think is not so easy to start with motion system to beginners. As you said, you haven't work with any plc yet. To begin with some basic tutorials would be good idea. Take a look in this link. It will help you a lot. http://www.mitsubishielectric.com/fa/assist/e-learning/eng.html returning to motion system. What you need to know: Before to start a code, you will need to wire the cables according the only way to work a QD75D__ with MR-J3__: Pulse train input . See the manuals. After that , you wiil need to configure the amplifier using GX-Configurator software. The next step in GX Works 2, add the QD75D_ as a inteligent function module and configure the module. You will need keeping in mind what kind of motion you want, all maths to gear relation and so on like you thinked your system As i said , not too easy. And finally the code you are talking about. The last thing that you do and the easyest ( if all your configuratios are ok).
christophertedjo Posted November 6, 2016 Author Report Posted November 6, 2016 On 11/4/2016 at 8:16 PM, AlexMota said: i think is not so easy to start with motion system to beginners. As you said, you haven't work with any plc yet. To begin with some basic tutorials would be good idea. Take a look in this link. It will help you a lot. http://www.mitsubishielectric.com/fa/assist/e-learning/eng.html returning to motion system. What you need to know: Before to start a code, you will need to wire the cables according the only way to work a QD75D__ with MR-J3__: Pulse train input . See the manuals. After that , you wiil need to configure the amplifier using GX-Configurator software. The next step in GX Works 2, add the QD75D_ as a inteligent function module and configure the module. You will need keeping in mind what kind of motion you want, all maths to gear relation and so on like you thinked your system As i said , not too easy. And finally the code you are talking about. The last thing that you do and the easyest ( if all your configuratios are ok). the wiring already done. i have configure the amplifier and plc parameter. thanks for your attention :)
AlexMota Posted November 7, 2016 Report Posted November 7, 2016 Ok, I got it. A good practice is jogging the servomotor by amplifier. Just to making sure the the circuit is working well. Take a look in this link. I think it will help you http://www.mitsubishielectric.com/fa/assist/e-learning/pdf/eng/1-Positioning_na_eng.pdf
christophertedjo Posted November 10, 2016 Author Report Posted November 10, 2016 On 11/7/2016 at 7:18 PM, AlexMota said: Ok, I got it. A good practice is jogging the servomotor by amplifier. Just to making sure the the circuit is working well. Take a look in this link. I think it will help you http://www.mitsubishielectric.com/fa/assist/e-learning/pdf/eng/1-Positioning_na_eng.pdf thank you very much alex. it help much
