Hello. I start learn GXW3  and i have problem with simulation. I trying to connect GT Simulator with GX simulator 3, but it's doesn't work. GT Simulator 3 easy connecting with GX Simulator and GX Simulator 2 and it's working. So i can't say that problem in GT Simulator 3, but GX Simulator 3 works too, when i starting it. All software configurated without any errors (IQW,GTW3,GXW3).
I using GX Works3 1.026C, GT Designer3 1.151H, IQ works (melsoft navigator) 2.12N.
  All time when trying to connect, popups this msg.
1.thumb.png.213e338e1a8dcb530437afd2ad8e
Settings of GTS3
23.png.589102b1aa1e3222f4373b611b7847af.
Note from HELP.
Quote
Checkbox
Enables a setting.
[Host]
Set a simulator as the host station.
[NW No.]
Set a network number.
The setting range is [0] to [239].
[PC No.]
Set a station number.
The setting range is [0] to [255].
[CPU No.]
Set a CPU number.
The setting range is [0] to [4].
[Connecting Simulator No.]
Set a system number and a CPU number appearing in GX Simulator3.
Enter a system number, a period (.), and a CPU number in that order.
The setting range of the system number is [1] to [64].
The setting range of the CPU number is [1] to [4].
If problem in this setting where i can see what i need to configure.
Note from help about this error. I have done this recommendation, but zer0 results.
Quote
Failed to connect with 'GX Simulator3'.
<ES:0x******>
An application was closed incorrectly.
Incorrect processing is activated.
Restart GT Simulator3 and GX Works3.
Restart the personal computer and start GT Simulator3.
Does someone know how fix this problem?
Edited by ClearMind
Settings of GTS3
Note from HELP.
Hello
Someone can help me i have some problem ...
Thanks in advance
best regards
Settings of GTS3
Note from HELP.
I am having same exact issue, except my driver is the iQ-F, so I am unsure of what the issue is. Thanks in advance.
