Hi
For a machine, when a fault appears, I would like to output (12,07) a pulse with variable lenght (T30)according to the fault (word 250)
So please take a look at the prg in attachment, section DISPLAY,
-In rung 1 to 33 a value is stored in word 250 when a fault appears,
-At the end of the section: timer 30:
The timer changes value when another fault appears, but the timer keeps on re-running so the puls never ends,
-At rung 34(313) I can't get marker 210,11 set,
So the output KEEPs getting high
Please help me. What am I missing?
Or is there a better way to do this?
Thank you
Labeler.cxp
Your XFER(70) instruction was being executed the entire time. This means it was holding your timer value at the Set Point and not allowing it to count down. See the attached image where I preceded it with an "@". This will make the instruction execute only once (One PLC Scan) on the rising edge. I also changed 210.11 from NC to NO and the Equals (EQ) Flag from NO to NC (Not shown in the image). This just made more sense to me when I was troubleshooting it.
LabelerFix.thumb.jpg.73f5c7daf9bee9a863e
Thank you for the effort, Your remark are worth mentioning but I found the main reason: (took me a few extra hours)
Words 250 and 251 are in the SR memory area which is used by the PLC itself.
So lesson learned: when using memory, always check out the appropriate memory areas
My apologies as I should have seen that. In order to simulate your program, I had to convert it to a CP1L where the memory areas are different. With the CP1L, CP1H, CS and CJ series PLCs, they have added "W" memory in which Omron promises never to be used by the system. This was a huge improvement for programming Omron PLCs for the reasons that you have encountered.
Omron's preferred method of dealing with numbers (as opposed to BOOLs) is to use "DM" memory. This memory is retentive. It has areas that are also used for the system, I think in the DM20000 range if I remember correctly . It's well documented but you'll need to know to look for it.
Good troubleshooting on your part!
Edited by IO_Rack
