applecruncher1 Posted November 29, 2016 Report Posted November 29, 2016 Hi, I've recently bought a generic RS232/TTY cable for Siemens S5 PLC. I also bought a RS232 -> USB converter to connect the cable to my laptop. My problem is that when I connect from S5 to Laptop and run PG2000, I cannot load anything from the PLC as the program gets stuck. I think nothing is being read from the converter. Please help. Here is my setup: S5 Siemens PLC http://i.imgur.com/kk3X7OU.jpg?1 RS232/TTY CABLE FOR S5 PLC http://i.imgur.com/SbkD2g9.jpg?1 RS232 TO USB CONVERTER http://i.imgur.com/Sy3C7hP.jpg?1 Thanks,
dekor Posted November 29, 2016 Report Posted November 29, 2016 First of all: if the black cable is the one from converter, then you have connect them into a wrong plug. It must be connected to PG marked (the one close to orange EPROM). If it is safe, disconnect the existing cable and put yours into PG marked plug. Please let us know what is your progress.
applecruncher1 Posted November 30, 2016 Author Report Posted November 30, 2016 Hi dekor, Thanks for the reply. Are you referring to this picture? Do you mean to say that the DB15 should be connected to the PG port (the silver one plug beside the EEPROM) ? Thanks,
dekor Posted November 30, 2016 Report Posted November 30, 2016 (edited) Yes, is that I want to say on my previous post. the actual place where your black cable is connected belong to analog inputs signals. Edited November 30, 2016 by dekor
applecruncher1 Posted November 30, 2016 Author Report Posted November 30, 2016 Hi dekor, Thanks for the prompt reply! I will try this and will update the results. Do I also still need special drivers from Siemen?
dekor Posted November 30, 2016 Report Posted November 30, 2016 No, you need only the driver of your USB-RS232. (As you asked on other forum)
applecruncher1 Posted November 30, 2016 Author Report Posted November 30, 2016 Alright I understand. Will update here soon.
applecruncher1 Posted December 1, 2016 Author Report Posted December 1, 2016 Hi dekor, Thanks for the advice! PG2000 is now able to read the data. Now my next problem is debugging the error.
dekor Posted December 1, 2016 Report Posted December 1, 2016 I am happy that you succeed to be connected with CPU! Do you think that you need more support? If you think so, please describe the problem and add some print screens. dekor
applecruncher1 Posted December 1, 2016 Author Report Posted December 1, 2016 Hi dekor, Please check this http://forums.mrplc.com/index.php?/topic/31852-stahl-hmi-outpur-error-db-not-available/#comment-149554 Thanks,
dekor Posted December 1, 2016 Report Posted December 1, 2016 Hi, The HMI is connected to PLC? Is the cable that you disconnected from PG port back on his place?
