I was called to one of my customer this morning who has one of tha above PLC,s. The problem is that there is a remote rack and  it is not talking to the main rack and the PLC is not in run mode. There is also DA001 analog module in the remote rack which was in error. I exchanged both the RM201 and RT201 modules the comms is still not working but the analog module is now in run. Both the Rm201 and the R201 are in alarm. The alarm is described as a duplex bus or intelligent I/O unit. The cable between the two units buses out ok.
any help on this would be appreciated
thanks
Rodney
Can you do a description of the condition of the indicator lights on both RM201 and RT201? (Lit, Flashing, Off)
Thanks for your posts. Jay
The RT201 has only the power indicator light. The RM201 has flashing fault light has does the CPU.
Rodney
Quote
What is the error code number in the CPU?
I have not seen an error code number only the description above. Any help in resolving this would be greatly appreciated.
Rodney
Just been to site and checked again using CX  Programmmer and I could see a code number. The error code number is 0x00D0.
Rodney
Edited by Rodney
Error has occurred in PC Link Unit, Remote I/O Master Unit, between a Host Link, SYSMAC LINK,or SYSMAC NET Link Unit and the CPU, or in refresh between Special I/O Unit and the CPUDetermine the unit number of the Unit which caused the error (AR 00), correct the error, and toggle the appropriate Restart Bit in AR 01, SR 250, or SR 252. If the Unit does not restart, replace it.
Special I/O Unit and the CPU = DA001
As mentioned in my original post the DA001 was in fault and when I replaced the RM201 and the RT201 the DA001 went into run.
Jay
Do I toggle the restart bits you mentioned the address I am writing to in the program is 100 if that helps
In the remote rack there the following l/O left to right
input module address 60
output module address 61
output module address 62
empy slot
DA001
Edited by Rodney
I reckon it is time to replace the lot - this old stuff has not been supported for years and cannot even be repaired.
Time to move on to a CJ2M - I would have done that years ago.
