smithers1 Posted January 9, 2017 Report Posted January 9, 2017 HiCan anyone give me pinout for FX1N to GOT2104 RS422 cable GT10-C10R4-8PHave looked on internet with no joy many thanks
Theo V Posted January 10, 2017 Report Posted January 10, 2017 Hi Smithers1, Check-out the GOT connection manual: http://www.koningenhartman.nl/UserFiles/Product/Datasheet/GT1000%20Serie%20Connection%20Manual.pdf Page 186 gives some diagrams for GOT 1000 series. You can give it a shot ot try it on the GT2104. (See attached picture) Best regards, Theo V.
smithers1 Posted January 10, 2017 Author Report Posted January 10, 2017 Hi Theo, thanks for that. Do you know what pin in the mini-din 8pin plug is attached to each color. Is brown pin 1, red pin 2, orange pin 3, etc. Many thanks
Theo V Posted January 11, 2017 Report Posted January 11, 2017 Hi Smithers1, I never opened a 8-pin plug but usually the order is from top to bottom in the list so I asume you are right about the order brown = pin 1 etc. I suggest that if you start testing the cable the first time just leave the white wire +5Vdc power not connected but use an external powersource for the GOT 5Vdc. Only connect the '-' from the 5Vdc to both GOT and PLC side (to close the loop). Aldough I think the port is galvanic isolated by opto-couplers you don't have the risk of destroying your FX PLC port due a wrong wire connection. As you noticed, there is not much info on the net about this subject. Perhaps because the original cable is around € 20,- euro and only the real hardcore electronic guys heat up the soldering iron to make a cable theirselfs just because it is possible... Don't take that personal but for that price I would just order a standard cable somewhere and save me the headache. It is up to you to decide. Succes! Best regards, Theo V. 2
smithers1 Posted January 11, 2017 Author Report Posted January 11, 2017 7 hours ago, Theo V said: Hi Smithers1, I never opened a 8-pin plug but usually the order is from top to bottom in the list so I asume you are right about the order brown = pin 1 etc. I suggest that if you start testing the cable the first time just leave the white wire +5Vdc power not connected but use an external powersource for the GOT 5Vdc. Only connect the '-' from the 5Vdc to both GOT and PLC side (to close the loop). Aldough I think the port is galvanic isolated by opto-couplers you don't have the risk of destroying your FX PLC port due a wrong wire connection. As you noticed, there is not much info on the net about this subject. Perhaps because the original cable is around € 20,- euro and only the real hardcore electronic guys heat up the soldering iron to make a cable theirselfs just because it is possible... Don't take that personal but for that price I would just order a standard cable somewhere and save me the headache. It is up to you to decide. Succes! Best regards, Theo V. Thanks for your help Theo, much appreciated 1
Akahige Posted March 22, 2017 Report Posted March 22, 2017 Smithers1 Try this diagram...if you haven't already figured out the wiring.
