Karnof Posted January 21, 2017 Report Posted January 21, 2017 Dear All, I will rebuild a old control panel with a new control panel. But I have a problem with a rectifier in the old one, there is a rectifier with 3 phase input 18 VAC out put 0 and -24 VDC, the type is DS10TK. I can't find any seller for this part. Any suggestion for this problem. Can I use any DC power supply like usually? Tank you very much. Karno
Mendon Systems Posted January 21, 2017 Report Posted January 21, 2017 That will depend on what is connected to the power supply. If it is just being used as a 24vdc supply then any supply adequate current should work.
