how to connect got2000 with FX3G direct through ethernet ?
FX3GE have a built-in FX3U-ENET-ADP on communication channel 1, so you need set up in plc enet module. Also need configure got.Try this settings.got.thumb.PNG.10a46eaaec6d9b23a22611a02ffx.PNG.7efe5ab1d24716ee4f61ec0f2322e0d9.
Edited by Clear.Mind
thank you mr Gambit  ,
but it still not working , could you please help me , if  have files explain the connection steps with examples
thanks in advance
Ok you are using the FX3GE so the port should be 5556 (port 5551 is for the ethernet module on the right side)
Can you change the GOT station number of the GOT to 2. (You should prevent having the same station numbers for GOT and PLC.
Lastly Did you create a MELSOFT connection in the ethernet parameters in GX Works 2?
Edited by Gambit
Looks fine.   Are you connected to a switch or is it a direct cable between GOT and FX?
If it's switch is anything else connected ?
Can you ping the PLC from the GOT or vice versa?
What do the ethernet diagnostic say from the PC side?
Edited by Gambit
