Jatin Posted March 1, 2017 Report Posted March 1, 2017 Hi everyone, We have GEFANUC 90-30 PLC installed in plant We are communicating to the PLC using versapro 1.10 software version but unfortunately that laptop is not working. So i tried installing another software version 1.50 but does not have registration key but software is working in trial mode for 4 days. I was able to install software on one another laptop which has Windows XP - OS installed on it. After that i tried communicating to plc using SNP Cable and it's getting connected. When doing upload of program and hardware configuration it's displaying message The current CPU setting does not match the CPU type of the attached PLC The current CPU type is IC200CPU001, the attached CPU type is CPU331 If i try hardware configuration change i can't see CPU listed in there. How do i upload program / hardware configuration from the PLC using Versapro software version 1.5 or how to amend hardware configuration of existing PLC into Laptop offline.
Steve Bailey Posted March 1, 2017 Report Posted March 1, 2017 You need to start a new project file using the 90-30 as the PLC type. The file you have been using is for a Versa Max Micro PLC.
Jatin Posted March 2, 2017 Author Report Posted March 2, 2017 Thanks Steve for the information, I will try this out.
