Stuart_Wales Posted March 28, 2017 Report Posted March 28, 2017 We're newbies to Siemens due to being a 90% Mitsubishi plant... T130 below, we believe, is set to 0ms. Then set via 'TV' under the DB105.DBW260 address. 1. What is the 'S5TH#' infront of the 0ms 2. When we go to change the value to 300 seconds, as suggested by machine builder, it allows us a max input of 9 seconds? Anyone know why? 3. Has anyone got a quick reference/link to timers in simatic/S7 for us? Thanks in advance.
omar_yousry Posted March 28, 2017 Report Posted March 28, 2017 Hello Stuart, The S5T# means the usage of time old format of Step5, as the time indicated in ms, this will limit your max, you can write the time format in S5T#0S format means in second instead of ms this will increase your max. otherwise you can use other new functions of timers. anyhow the good thing about Step7 that you can select any block like the T130 and click "F1" on your keyboard, this shall open the help and inside you can see information about all input and outputs of that block with all possible formats, plus brief description of its function and one or two example to understand how it works. Have fun Omar 1
Joe E. Posted March 28, 2017 Report Posted March 28, 2017 You have other time bases available as well. Instead of 300s, you can use "5m" for 5 minutes. If you hit "F1" on the timer instruction, there will be a link to "Location of a Timer in Memory and Components of a Timer". That article will explain the structure and syntax of the time base. That article then has alink to S5TIME datatype that unpacks the bytes and bits in case you have to build it from scratch at run time. You can also open up the standard library and look under System Function Blocks for SFB4 and SFB5 which are on and off delay timer blocks. They operate as any other FB, so you need an instance DB for each call. Those instances can be inside another DB if you want. 1
Stuart_Wales Posted March 28, 2017 Author Report Posted March 28, 2017 Thank you both! Next question (haha!!). I've had a bash at de-coding the instruction below. Am I close or way off: A T 140 ;AND Timer 140 FP M 6.4 ;Load 6.4minutes into the timer (I think) JC M001 ;Jump condition to M001 (I think) JU M002 ;Jump up to M002 (I think) M001: L DB100.DBW 40 ;Load DB100.DBW (which is our real time temperature) L 10 ;Load a constant of 10 +I ;Add the two above integers (this is the real time temp + 10 degrees) T MW 120 ;Transfer into MW 120 M002: NOP 0 ;Jump to here if M002 is ON In a nutshell, we're looping the M001 function, and I'm assuming to get out of it, M001 needs to go OFF and M002 ON (I haven't monitored this far into it yet...)
Joe E. Posted March 28, 2017 Report Posted March 28, 2017 (edited) I don't know off hand what the "FP" instruction is and I closed down that virtual machine to work on something else, but that doesn't look right. If you make a simple ladder logic network with the timer instruction configured the way you want, you can convert the network to STL to translate that portion. I think it's on the "view" menu, or you can hit CTL-1, CTL-2, and CTL-3 to change languages between LAD, FBD, and STL. Looping, you're going to have to play with because I try not to do that if I can avoid it because I really don't enjoy troubleshooting/debugging in STL, or getting phone calls at 2AM because a maintenance guy gets lost in the code. Edited March 28, 2017 by Joe E.
Stuart_Wales Posted March 28, 2017 Author Report Posted March 28, 2017 Worked it out now lads. The JC is a condition jump of the M6.4 (so only jump if HIGH or '1') then the JU is an unconditional jump which will jump the scan regardless of polarity of bit. The F1 function is brilliant, so thanks for that tip both!!
