Hello Mazen_abs,
At least you need the GX-Works or IQ Works software to download. I'm not sure if the FX5U has a build in webserver. In the FX3 series there is. Just type in the IP number of the FX5U in your internet explorer tot test.
To connect make sure your laptopp/PC networkcard is in the same IP range and subnetmask as the FX5U. Modern laptops from Dell and HP can handle straight and cross RJ45 cables. If you are not sure just put a simple ethernetswitch in between the computer and the PLC. Than you have straight cable connections only.
Best regards,
Theo V.
