chrisb4748 Posted April 6, 2017 Report Posted April 6, 2017 Hi, I am trying to indirectly index 1 D register, into 999 ZR registers. i.e. I have 999 dollies that are going through the factory. Each with an individual carrier ID. I want to use 1 D register to pick up that carrier ID and enter it into the corresponding ZR Register. If Carrier ID is 123 I want D990 to enter that into ZR60123 Or Carrier ID is 598 I want D990 and enter that into ZR60598. How should I go about this? Many Thanks
Gambit Posted April 6, 2017 Report Posted April 6, 2017 Depends on your programming software. In direct mitsubishi code this would be. MOV K123 Z0 MOV D.... ZR6000Z0 (ZR6000 + 123). However it is also possible to write an address into a Registers and then use @ to indicate it is an indirect address. If you use structured programming you should make an array for ZR6000 ...... Then it would be something like: Mov K123 Mypointer Mov MyValue MyArray[MyPointer]
chrisb4748 Posted April 6, 2017 Author Report Posted April 6, 2017 I am using GX Works2. Is there another way of doing this? The way you have described "K...." will be changing so I couldn't use a constant. My client has a new RFID system installed and is wanting to be able to select the different dollies through out the factory. And in reference to the "Mypointer" could you explain further into that as I'm not 100% sure.
Nightfly Posted April 6, 2017 Report Posted April 6, 2017 I personally find structured text is much easier (and clearer) to use when dealing with arrays/indexes With “Dollies” declared as a zero based array of 1000 int’s starting at ZR60000 [0..999] and “CarrierID” declared as an Int and D990 has a value 888 When “CarrierID” has a value of 0 then the statement... Dollies[CarrierID] := D990 would put the value of 888 into ZR60000 When “CarrierID” has a value of 123 then the statement... Dollies[CarrierID] := D990 would put the value of 888 into ZR60123 When “CarrierID” has a value of 990 then the statement... Dollies[CarrierID] := D990 would put the value of 888 into ZR60990
Gambit Posted April 6, 2017 Report Posted April 6, 2017 19 minutes ago, chrisb4748 said: I am using GX Works2. Is there another way of doing this? The way you have described "K...." will be changing so I couldn't use a constant. My client has a new RFID system installed and is wanting to be able to select the different dollies through out the factory. And in reference to the "Mypointer" could you explain further into that as I'm not 100% sure. K was just an example to make it clear this could alos be a word The My pointer is the same as the 123 in the previous example. It's just the word containing the needed offset
chrisb4748 Posted April 6, 2017 Author Report Posted April 6, 2017 3 minutes ago, Nightfly said: I personally find structured text is much easier (and clearer) to use when dealing with arrays/indexes With “Dollies” declared as a zero based array of 1000 int’s starting at ZR60000 [0..999] and “CarrierID” declared as an Int and D990 has a value 888 When “CarrierID” has a value of 0 then the statement... Dollies[CarrierID] := D990 would put the value of 888 into ZR60000 When “CarrierID” has a value of 123 then the statement... Dollies[CarrierID] := D990 would put the value of 888 into ZR60123 When “CarrierID” has a value of 990 then the statement... Dollies[CarrierID] := D990 would put the value of 888 into ZR60990 I have never written in structured text, but appears to be the easiest way to go about this. Could you give me some advice on doing this? Thanks
Gambit Posted April 6, 2017 Report Posted April 6, 2017 (edited) Structured is indeed very flexible but maybe my explanation was not so good so here is an actual example. MyDataword is the value you want to move Carrier ID is only the offset (123) MyArray starts at ZR60000 But like @chrisb4748 already mentioned Structured text is also a good way of doing this. Edited April 6, 2017 by Gambit
chrisb4748 Posted April 7, 2017 Author Report Posted April 7, 2017 Thanks for that help yesterday guys.
