Guest csooi Posted December 17, 2004 Report Posted December 17, 2004 Does anyone out there have PL7-2 software to sell for programming old TSX 17-20 PLC. PLC is dated 90-94 . Tried Schneider already , but they do not have for old phased out models only the newer ones. They asked to replace old units with new ones - but too expensive. Also EPROM modules TSX P720FA ver 1.5 - URGENT need Quote
s66knot Posted December 27, 2004 Report Posted December 27, 2004 3 disquettes sont nécessaires soft pour toute les séries 17 et 47 (hors 40). pl722_v5_dos.exe Quote
Guest Guest_Ben Posted January 23, 2005 Report Posted January 23, 2005 Trop fort. Merci. Y a besoin d'un dongle pour le faire marcher? J'ai entendu dire ca... (Thanks. Do you need a dongle to make it work? I heard that... ) Ben. Quote
Crossbow Posted January 26, 2005 Report Posted January 26, 2005 Later releases of PL7-2 did not require the old parallel port dongles. I have a couple dongles and keys which are destined for the dumpster, but the version of PL7-2 I have does not require a dongle. Quote
pressure Posted January 4, 2007 Report Posted January 4, 2007 Hi , I know that this post is a bit old but anyone can repost the software? i really need this Quote
chrisw Posted February 3, 2010 Report Posted February 3, 2010 Trying to download pl722_v5_dos.exe I keep getting an error - is this file still available? Thanks, Chris W Quote
