pfort Posted April 22, 2017 Report Posted April 22, 2017 Working at home this morning, so no PLC available here for trying my program. So I started the simulator, but I got an error message: Failed to read file card details. Check that the file card is inserted and is correctly formatted. Then I hit OK button on this and the same message reappear once. When I hit again OK, I get another message: Not enough file space on the PLC! Then it "disconnect" the simulator. I have no idea what is supposed to be that file card. Maybe the memory card that we can use in CP1L, but I never used any. Any suggestion someone?
Mendon Systems Posted April 22, 2017 Report Posted April 22, 2017 That's definitely kinda weird! The only thing I can think of is to check the PLC device type to make sure it is set to CP1L.
pfort Posted April 22, 2017 Author Report Posted April 22, 2017 Just now, Mendon Systems said: That's definitely kinda weird! The only thing I can think of is to check the PLC device type to make sure it is set to CP1L. Yes it is (Weird and CP1L). I started new project with another CP1L, and writed 1 rung, then tried simulator with same result. Then I tried a new project with a CJ2M and simulator worked. So I converted my project to CJ2M and now I can simulate (and fix my mistakes). So monday I will reconvert it to CP1L, and maybe reinstall CX-Programmer. I recall I had another weird error message this week, about FB. Thanks
Mendon Systems Posted April 22, 2017 Report Posted April 22, 2017 I tried the CX-P version 9.6 simulator here with one of my CP1L programs and it worked fine, so I don't really have any idea what to tell you. I guess what you are doing is about the best idea until you can sort it out.
imblink Posted July 22, 2017 Report Posted July 22, 2017 (edited) I can fix this problem with online simulator. Step 1: Change in option > PLC > Uncheck Automatically transfer program to simulator Step 2: Click on Simulation > Work Online Simulator Step 3: Click Transfer to PLC, In this step the error will appear again, no problem Step 4: where it is written "Transfer to /From: Memory card" Change for Comment Memory Step 5: Some errors will appear but you will be able to transfer the program and simulate online, it was the only way I could, I still do not know why this error. Images att Edited July 22, 2017 by imblink 2
Fernand Posted March 11, 2020 Report Posted March 11, 2020 Imblink, You've saved my (job) life !!! TNX!!!
