regards
how can i declare a string variable on sysmac? can you bring me an example?
ex.
var _a = type array[0..2] of string[20]
how can i put this string "hello world" on var_a[x]?
var_a[x]:="hello world"
that is correct?
thanks
Name                        Data Type                                                 Initial Value
var_a         ARRAY[0..2] OF STRING[20]         ['hello world 1', 'hello world 2', 'hello world 3']
If you input STRING[20][3] in the Data Type field it will convert it automatically to look like the above. You don't have to populate the Initial Value field. You can write to it at runtime.
thanks io_rack
so can i to put this in my code?
ex.
var_a                      STRING[20][3]  = 4 strings of 20 right? or =( STRING[20][1],STRING[20][2],STRING[20][3]
var_a[0]:='hello'               //this is correct? the value asigned to my first string of 20 its equal to 'hello'?
var_a[1]:='world'            //var_a[1] contains the string 'world'?
regardas
