Stuartjl Posted May 18, 2017 Report Posted May 18, 2017 Hi, i'm having a bit of trouble connecting my GOT 2508 to Q12 plc via ethernet. I have follwed the advice that GOT manuals have given me but i still cannot connect. I belive my GOT setting are correct now, but entirely sure they are correct in my Q12. I'm using GX IEC Develope 7.04. Thanks, Stuart
Gambit Posted May 18, 2017 Report Posted May 18, 2017 Can you give us your settings for your ethernet settings on the PLC and the HMI.
Stuartjl Posted May 19, 2017 Author Report Posted May 19, 2017 Hi Gambit, thanks for the reply. Please see attached. Thanks, Stuart
Gambit Posted May 19, 2017 Report Posted May 19, 2017 The connection to the from the HMI to the PLC is UDP not TCP. (take a look at your last screen capture...... 5006 UDP) You have to set up a melsoft connection but for UDP 1
Stuartjl Posted May 22, 2017 Author Report Posted May 22, 2017 On 19/05/2017 at 1:56 PM, Gambit said: The connection to the from the HMI to the PLC is UDP not TCP. (take a look at your last screen capture...... 5006 UDP) You have to set up a melsoft connection but for UDP Hi, thanks for the Help. It seems the first issue was the GOT station number. I've got it as 1 in the above setup, it should be 60. Going play around with the melsoft settings for UDP as i have it working on TCP. Stuart
