Amogh Posted May 23, 2017 Report Posted May 23, 2017 Thanks for the help in advance i am using mitsubishi fx3g-40mr plc 1] i am reading data from camera on serial port. The data camera send is ASCII character if camera send 0 i receive 48 if it is 9 i receive 57 which i under stand but when camera send 00 i receive 12336 and for 01 it shows 12592 it increment by 256 Please some one would tell me 2] And if camera send 000 the data receive is 12336 in first resistor and 48 in other is there some command which i can use directly for this conversion or any other type any help is appreciated
Gambit Posted May 23, 2017 Report Posted May 23, 2017 (edited) Please See the table below. It's just interpertation you are looking at it as a decimal. ASCI (char) 0 = DEC 48 ASCI (char) 9 = DEC 57 Change your setting in GX-.... to translate into ASCII and you will see the text. Decimal 12336 = Hex 3030 Decimal 48 = Hex 30 Hex 30 (see table above ) = 0 ASCII Each Data register contains 2 ascii character. So the first 8 bits and the second 98 bits. thats why you have to look at in in HEX or ASCII. Edited May 23, 2017 by Gambit
