Hello Friends
I have a FX3G-24MR/DS and I need to read a barcode from a Cognex DMR-8050-0100 barcode reader.
Do I need a serial module? Which one?
how can I get the barcode in the program?
Do you have some sample program?
I am newbie in Mitsubishi plc, any help would be very appreciated.
Best Regards
A serial module will work, FX3U-232ADP module should be sufficient if you want to stick with 232. I've configured several Cognex devices on QCPU's with built in ethernet using MC protocol and it was a breeze, much easier than 232 (for me at least). I would consider using ethernet with a  FX3U-ENET-ADP. I haven't used MC protocol on FX's , but hopefully it's as simple as on a Q.
Hello
The problem is that the Plant has bought a serial barcode reader, so I have to use this.
Antoher problem, is that there are not space in the cabinet for anything. So, FX3U-232ADP could no be used. I have look a FX3G-232-BD expansión board, this could be above the PLC, so the space is not problem.
Do you know if I could use FX3G-232-BD to connect a barcodereader?
Thanks a lot.
Yes, you can use the BD card for serial communication, like the ADP cards. Also for barcode readers.
Edited by kaare_t
Forgot a sentence
