venza Posted June 5, 2017 Report Posted June 5, 2017 Hi all! I want to convert programe from S5 to S7 How to way upload programe S5, type cable and software can i use? I have laptop (PCI Express to Com), PC adapter USB A2, software PG2000, S5S7 for window, SIMATIC MANAGER V5.5, TIA PORTAL V14. Please help me!
dekor Posted June 5, 2017 Report Posted June 5, 2017 Hi, first of all you need an TTY adapter to connect your PC to PLC S5. Connect your TTY adapter to your com port. Then, you may use PG2000 software to Upload PLC program into PC. Set your PG2000 communication to your com port according PCI Express settings. Then press Open/PLC. After upload PLC program, save it with a short name. Be sure that your PG2000 is not on "DEMO" mode.
venza Posted June 5, 2017 Author Report Posted June 5, 2017 Hi dekor! Type cable as image below can connect? I'm bought at ebay.com but it's "made in China"
dekor Posted June 5, 2017 Report Posted June 5, 2017 Looks to be the right one. Check what "com" has been assigned by your PCI Express adapter. Go to system/ hardware configuration and see there what number has your serial port. For example you will find Com 3. Then, start your PG2000 and go to Options/Interfaces and choose PLC-interface also Com 3 as in hardware configuration. Dont change other things there. Then go to File/Open and select PLC Now, you have to be sure that your PG 2000 is not a "DEMO". If you still have questions, please, fell free to ask.
venza Posted June 6, 2017 Author Report Posted June 6, 2017 Hi Dekor! I trial & upload programe from Simatic S5 95U via PG2000 succuessful. And now i will be convert programe up S7 300. Thank You very much! Have a nice day!
