dipen_95 Posted June 13, 2017 Report Posted June 13, 2017 I current have 2 variable: Displacement vs Pressure. I need to draw a real time graph on Comfort Panel. The problem with using just f(x) trend is that the minimum time between updating a point is 0.5 sec and that is for ever in my application as the whole cycle last only 5 sec and I have to plot 500 points in that time. Is there a way to do real time graph using Historical data without any time delay. If anybody can guide me through any sample program or material would e helpful. Thanks
Bryll Posted June 15, 2017 Report Posted June 15, 2017 I would use the PLC memory to store your samples since you want a resolution ten times better than the update rate between the panel and PLC. Use a time delayed interrupt to store your samples.
dipen_95 Posted June 15, 2017 Author Report Posted June 15, 2017 Thanks for the reply. Now storing the sample is not a problem. I can store all the values I get in my auto cycle time inside the PLC. But when it comes to drawing a X vs Y trend on screen there is where the issue is. I cannot draw in Real time so is there a way I can draw from an Array instead of just a variable.
Bryll Posted June 16, 2017 Report Posted June 16, 2017 I'm not sure, but it might be possible to use the "f(x) trend view".
