Guest Raul Vega Posted December 22, 2004 Report Posted December 22, 2004 I have installed Quantum 434 12A (before 424 02) with proworx NxT. My problem is when I programmed and i do a search for example sometime shatdown CPU and trigger 8 flashes in Run Led CPU.(Kernel error). I replaced CPU, backplane, power,firmaware and nothing. The comms are with Ethernet TCP/IP in Windows2000. I don´t know if problem is with Proworx or TCP/IP. I will do upgrade in future Nxt to Concept LL984, but I have problem with convertion Profibus database, Saludos desde CHILE Quote
