Jimbravo Posted July 14, 2017 Report Posted July 14, 2017 Hi all, I have an upcoming project to upgrade an older GE PLC at a facility to a newer GE PAC system. I was told the older PLC was programmed in ControlST, and I will need Proficy for the new equipment. I've been trying for a few days now to get ahold of a copy of ControlST through GE and my local distributor but haven't had any luck. I came across a few lines of text in the Proficy brochure and around the internet that led me to believe that Proficy is somewhat backwards compatible and can pull the program out of some GE PLC's programmed with older GE software. Can anyone tell me if I would be able to use Proficy to view and download from a PLC programmed with ControlST? Thanks for any help!
RussB Posted July 17, 2017 Report Posted July 17, 2017 Proficy is very backwards compatible with LogicMaster and with its self but not with other programming packages used by GE Fanuc/GE processors. I don't know what is meant by ControlST but if you mean the old Cimplicity Control, then not so much but here is the procedure. Search here for more information on this.
Jimbravo Posted July 17, 2017 Author Report Posted July 17, 2017 Hi Russ, Thanks for the response. Without having been to the site yet, what I know so far is that they are using a GE Innovation Series controller programmed with Control Systems Toolbox; I may have incorrectly assumed this is what ControlST stood for. On another note; does anyone know how I could get a hold of the GE Control Systems Toolbox software? I've been in touch with numerous people at GE and three of my local distributors, and no one seems to be able to have a way for me to purchase or download this.
RussB Posted August 1, 2017 Report Posted August 1, 2017 On 7/17/2017 at 3:13 PM, Jimbravo said: Hi Russ, Thanks for the response. Without having been to the site yet, what I know so far is that they are using a GE Innovation Series controller programmed with Control Systems Toolbox; I may have incorrectly assumed this is what ControlST stood for. On another note; does anyone know how I could get a hold of the GE Control Systems Toolbox software? I've been in touch with numerous people at GE and three of my local distributors, and no one seems to be able to have a way for me to purchase or download this. The people here will be able to help with that: https://ge-ip.force.com/communities/CC_Contact
RussB Posted August 1, 2017 Report Posted August 1, 2017 This was put on the GE Support site a few days age: https://ge-ip.force.com/communities/en_US/Documentation/ControlST-Release-Notes-GEI-100746
