b.k.n. Posted July 17, 2017 Report Posted July 17, 2017 I am using the NS series touch screens and NS-Runtime. Do they have a System word that stores the IP address of that touch screen or PC running the NS-Runtime application. I want to be able to trigger different functions in my project depending on the IP address.
Crossbow Posted July 17, 2017 Report Posted July 17, 2017 Nope. You can always make a variable in the PLC and have the HMI put a value in it.
b.k.n. Posted July 17, 2017 Author Report Posted July 17, 2017 Just now, Crossbow said: You can always make a variable in the PLC and have the HMI put a value in it. Yea but how do you go about getting the IP address of the touch screen to put in that variable??
Crossbow Posted July 17, 2017 Report Posted July 17, 2017 As I said, you can't, you would need to set a variable of your choice.
b.k.n. Posted July 17, 2017 Author Report Posted July 17, 2017 I'm afraid we are missing each other. What I wanted to no is how can I get the IP address of the Touch Screen and move it into a variable. The reason I want this is so I can change the Touch Screen's program behavior automatically depending on it's IP. This will keep me from having a different program for every one of the Touch Screens on the site...
IO_Rack Posted July 18, 2017 Report Posted July 18, 2017 (edited) I think Crossbow understands you correctly. To the best of my knowledge, there is no way to transfer the IP address to a variable. To see what information is available, take a look at PT > System Settings > Initial (tab) > System Memory List. You can also look at the Macro Reference Manual. There are some well experienced Omron guys here. If there is some clever method of doing this, I'm sure they'll respond. If you want to use the same program for all touch screens then create a settings screen where you can use a Numeral Input/Display object to input a variable (as Crossbow has mentioned). (Maybe the last octet of the address). All the programs can be the same but the downside is, you'll have to change this variable when you change the IP address. Edited July 18, 2017 by IO_Rack
Michael Walsh Posted July 19, 2017 Report Posted July 19, 2017 On 7/17/2017 at 3:51 PM, b.k.n. said: I'm afraid we are missing each other. What I wanted to no is how can I get the IP address of the Touch Screen and move it into a variable. The reason I want this is so I can change the Touch Screen's program behavior automatically depending on it's IP. This will keep me from having a different program for every one of the Touch Screens on the site... Why don't you have a password protected area that you used to enter a value in a retained NS variable ($HW)? You can then use that number to make it respond differently.
b.k.n. Posted July 22, 2017 Author Report Posted July 22, 2017 Okay thanks for your input I might have to do the thing of entering a value into a ($HW). Its just I was hoping that it could be auto populated off of the last octet of the IP. Thanks any way.
