Milosh Posted July 20, 2017 Report Posted July 20, 2017 (edited) Hi all... I want to scale data from analog input which I defined as Name: _LEVEL Type: CHANNEL I defined also next D words D10000 - ParamControlWordLevel UINT D10001 - ParamAnalogLowLevel INT D10003 - ParamOutLowLevel REAL D10005 - ParamAnalogHighLevel INT D10007 - ParamOutHighLevel REAL Scaled variable is MeasureLevel REAL W20 I have set on PLC first cycle ParamControlWord=#0201, use floating point with one linear segment, ParamAnalogLowLevel=#0000, ParamAnalogHighLevel=#4000 (current input). ParamOutLowLevel and ParamOutHighLevel sets administrator from touch panel. APR Call parameters are 1. Control word = ParamControlWord 2. Source = _LEVEL 3.Result = MeasureLevel Is this good configuration? What if I have something in Source word (etc. #1160), but Result is zero (+0.0). Best regards, Milos Edited July 20, 2017 by Milosh
