robinshion Posted July 24, 2017 Report Posted July 24, 2017 Hi, guys, I am using NB designer. any one knows How to set screen change with PLC??
BITS N BYTES Posted July 24, 2017 Report Posted July 24, 2017 NB_series_StartupGuideManual_en_201402_V109-E1-08.pdf
robinshion Posted July 25, 2017 Author Report Posted July 25, 2017 Thanks for your reply, I had the pdf and I look but it seems change screen in hmi and plc not know. like I use the move function I set the frame to H10, it doesn't work. thanks again
Michael Walsh Posted July 25, 2017 Report Posted July 25, 2017 Under the Project Database section of the Library Window, you can add a PLC Control as shown below: Then you can point the "Switch Screens" control event to the addresses (2 consecutive) that you want to use. See the description of Switch Screens below:
EL-HADIRI Posted July 24, 2020 Report Posted July 24, 2020 hello i have the same problem , i have do the same steps but the screen still not changed. i work with a CP1L and NB 7W-TW00B
