alirh Posted July 29, 2017 Report Posted July 29, 2017 hi guys, i am really need your help, i am still new in plc programming. i have cj1w-nc213 PCU and cj2m-cpu11 PLC to control mitsubishi mrj2s-100a servo. when i pressed the start button, the output x axis was lit and run lamp lit. and no error seem occured, but the output doesnt appear. what should i do to fix this problem? please see attechment file below tes 1 not run.cxp
BITS N BYTES Posted July 29, 2017 Report Posted July 29, 2017 Unit number in your program is 0 and Operating data area designation is allocated to SIOU in the PLC IO Table. Check rotary switches on position control unit are set at 0. Starting DM area for this position control unit starts at DM2000 and CIO Operating memory starts at CIO2000. You need to modify your program to map to the correct areas.
Jay Anthony Posted July 30, 2017 Report Posted July 30, 2017 Quote Starting DM area for this position control unit starts at DM2000 and CIO Operating memory starts at CIO2000 Starting DM area for this position control unit 0 starts at DM20000
alirh Posted July 31, 2017 Author Report Posted July 31, 2017 hi, thankyou for your answer, but, to be honest i not really understand. would you like to give me an example for this problem. sorry for being rude. this is really big problem for me
