Abdul Wajid Posted August 2, 2017 Report Posted August 2, 2017 (edited) Dears Can anyone clarify me in NB-designer how to display/design messages for different no. of states based on the conditions by triggering different states (moving states value) in particular data register ? Thanks Edited August 2, 2017 by Abdul Wajid
Abdul Wajid Posted August 4, 2017 Author Report Posted August 4, 2017 (edited) On 8/2/2017 at 6:22 PM, BITS N BYTES said: Use the Event Display function. Thanks Gentleman Edited August 4, 2017 by Abdul Wajid
Abdul Wajid Posted August 18, 2017 Author Report Posted August 18, 2017 (edited) On 8/2/2017 at 6:22 PM, BITS N BYTES said: Use the Event Display function. Hi... BITS N BYTES Can you clarify me how to set up different events (messages) for different screens to trigger on different conditions? So when i tried to set multiple messages on the same event setting (can't use different event setting) with multiple data registers, then on triggering any one condition ,multiple messages of different data registers occurs simultaneously (together) for separate (multiple) event display function . But i want to know how appear multiple messages appears on multiple display function on multiple screens if particular conditions gets triggered . Meanwhile i need to know the same settings for Alarm Function & displays also as mention above. Also i want to know regarding the Type tab (range 0 - 255) on event settings function. What does it means ? Kindly help me to sort out the issue Thanks Edited August 20, 2017 by Abdul Wajid
