Phillauria Boyz Posted August 5, 2017 Report Posted August 5, 2017 hello everyone.. i want to know about how to activate a output ( i.e yo, y1 etc ) using cc-link..
Clear.Mind Posted August 5, 2017 Report Posted August 5, 2017 (edited) For better understanding read this courses - Learning . Edited August 5, 2017 by Clear.Mind 1
Crossbow Posted August 7, 2017 Report Posted August 7, 2017 Nobody can help you. You have not provided one bit of useful information. What PLC? What CC-Link modules do you have? How is it connected? What have you tried? Until you tell us the details, we are not going to sit here and guess...
Phillauria Boyz Posted August 11, 2017 Author Report Posted August 11, 2017 PLC Model is Q00UJCPU CC-Link Model is QJ61BT11N Input Model is QX42-s1 Output Model is QX42P Programming Software Gx Developer Version 8
kaare_t Posted August 15, 2017 Report Posted August 15, 2017 You need some sort of remote I/O too. I'm guessing you have connected the QJ61BT11N to the CPU, QX41-S1 and QX42P are also connected to the CPU. What is your remote node?
NgoHoang Posted August 25, 2017 Report Posted August 25, 2017 On 8/15/2017 at 5:13 PM, kaare_t said: You need some sort of remote I/O too. I'm guessing you have connected the QJ61BT11N to the CPU, QX41-S1 and QX42P are also connected to the CPU. What is your remote node? Dear! I also CPUQ03 and QJ61BT11N, If I have 1 master and 4 slave, how to send data from master to only slave 3? Thanks and best regard. Config Master as below
kaare_t Posted August 26, 2017 Report Posted August 26, 2017 You need to calculate where the start addresses are for the specific node, based on the Station Information settings. For example: Slave 1 = 32 I/O Y1000-Y101F Slave 2 = 64 I/O Y1020-Y105F Slave 3 = 32 I/O Y1060-Y107F in other words, in the example Slave 3 will have a start digital output address: Y1060
