Hello,
I have a problem with sending encoder pulses to GOT2000. I got a FR-A800 inverter (with encoder) and connected HMI to it. I dont know what device should I use in GT Designer to read those pulses propely. In parametr 52 on inverter i have "19" so I can see pulses on monitor(FR-DU08) but I have no idea how to send it to HMI.
Any ideas ?
Regards,
Paul
Edited by retry92
Simply search for the "definition" in GOT Device Search (see picture). You can search up parameters etc. etc. by searching with "Definition" in GT Designer: You want to use a display, Pr369
I have not tested with this encoder parameter before, but it should work - give a feedback :-)
P.S. You don't need to assign 19 to pr52 to be able to show the encoder pulses in the GOT. The GOT can read directly from the parameters without assigning anything to the PU monitor.
Thanks for reply, kaare_t !
So, somehow I managed to make it work. The solution was to write to numerical display SD1166 in Designer :) now I can see pulses on GOT display clearly.
Thank you for help,
Paul :)
