Hello,
I would like to make a graf bar like in siemens HMI's. I mean that the bar will fill up with the color and change for another color for higher values . It is possible to do it with SysMac Studio? Can anyone help me with this topic :)
thx it's help a lot
It's possible to connect value of color range with some variable? That we can set this value from HMI panel and changed for different items? I would like to do adjustable color range not fixed form Animations tab.
Edited by marcinmrag
In the Animations tab, use a variable of your choice (it's not fixed). In this example I used a tag called Level. The easiest way to test this is to create a new project, drag a Rectangle and a Slider to the screen. Set the Slider tag to 'Level' then simulate it. Maybe I don't understand your question. What is the application?
MrPLC_Animation.jpg.d7f07469c8bbeb7b0aba
I would like to set "StartValue" for the ColorRanges form other page. Use some edit data window put there for example 50 and change this in animations tab. Is possible to connect another variables just to change this value?
Not currently possible for the color ranges to be tied to variables, only numeric values.
If anyone is interested.
You draw a bunch of lines on the screen
1 )  Define them as an array - In the example given, it is two-dimensional
#Region "Lines"
Public Lines( , ) As Omron.Hmi.ElementLibrary.Path = {  _
Line0,Line1, Line2, Line3, Line4, Line5, Line6, Line7, Line8, Line9, _
Line10, Line11, Line12, Line13, Line14, Line15, Line16, Line17, Line18, Line19, _
Line20, Line21, Line22, Line23, Line24, Line25, Line26, Line27, Line28, Line29, _
Line30, Line31, Line32, Line33, Line34, Line35, Line36, Line37, Line38, Line39, _
Line40, Line41, Line42, Line43, Line44, Line45, Line46, Line47, Line48, Line49 }, _
Line50, Line51, Line52, Line53, Line54, Line55, Line56, Line57, Line58, Line59, _
Line60, Line61, Line62, Line63, Line64, Line65, Line66, Line67, Line68, Line69, _
Line70, Line71, Line72, Line73, Line74, Line75, Line76, Line77, Line78, Line79, _
Line80, Line81, Line82, Line83, Line84, Line85, Line86, Line87, Line88, Line89, _
Line90, Line91, Line92, Line93, Line94, Line95, Line96, Line97, Line98, Line99 }, _
Line100, Line101, Line102, Line103, Line104, Line105, Line106, Line107, Line108, Line109, _
Line110, Line111, Line112, Line113, Line114, Line115, Line116, Line117, Line118, Line119, _
Line120, Line121, Line122, Line123, Line124, Line125, Line126, Line127, Line128, Line129, _
Line130, Line131, Line132, Line133, Line134, Line135, Line136, Line137, Line138, Line139, _
Line140, Line141, Line142, Line143, Line144, Line145, Line146, Line147, Line148, Line149 }, _
Line150, Line151, Line152, Line153, Line154, Line155, Line156, Line157, Line158, Line159, _
Line160, Line161, Line162, Line163, Line164, Line165, Line166, Line167, Line168, Line169, _
Line170, Line171, Line172, Line173, Line174, Line175, Line176, Line177, Line178, Line179, _
Line180, Line181, Line182, Line183, Line184, Line185, Line186, Line187, Line188, Line189, _
Line190, Line191, Line192, Line193, Line194, Line195, Line196, Line197, Line198, Line199 }, _
Line200, Line201, Line202, Line203, Line204, Line205, Line206, Line207, Line208, Line209, _
Line210, Line211, Line212, Line213, Line214, Line215, Line216, Line217, Line218, Line219, _
Line220, Line221, Line222, Line223, Line224, Line225, Line226, Line227, Line228, Line229, _
Line230, Line231, Line232, Line233, Line234, Line235, Line236, Line237, Line238, Line239, _
Line240, Line241, Line242, Line243, Line244, Line245, Line246, Line247, Line248, Line249 }, _
Line250, Line251, Line252, Line253, Line254, Line255, Line256, Line257, Line258, Line259, _
Line260, Line261, Line262, Line263, Line264, Line265, Line266, Line267, Line268, Line269, _
Line270, Line271, Line272, Line273, Line274, Line275, Line276, Line277, Line278, Line279, _
Line280, Line281, Line282, Line283, Line284, Line285, Line286, Line287, Line288, Line289, _
Line290, Line291, Line292, Line293, Line294, Line295, Line296, Line297, Line298, Line299 }, _
Line300, Line301, Line302, Line303, Line304, Line305, Line306, Line307, Line308, Line309, _
Line310, Line311, Line312, Line313, Line314, Line315, Line316, Line317, Line318, Line319, _
Line320, Line321, Line322, Line323, Line324, Line325, Line326, Line327, Line328, Line329, _
Line330, Line331, Line332, Line333, Line334, Line335, Line336, Line337, Line338, Line339, _
Line340, Line341, Line342, Line343, Line344, Line345, Line346, Line347, Line348, Line349 }}
    #End Region
2) You are writing a handler for line properties.
Sub Test_LineAll
    Dim n  As Short
' The loop of iterating over lines is a new option for passing in 1 time
If Draw Then
        Cnt_prohodov =0
        Draw = False
        NL = 0
End If
If Cnt_prohodov < 2  Then
            If NL < 6  Then
                NL = NL+1
            Else
                Cnt_prohodov = Cnt_prohodov +1
                NL = 0
            End If
                     If   Line_Set(NL).IsVisible Then
                                  Line_Raschet1(NL) 'Let's pull the Full_Height value to the height of the Current window.
End If
                For n = 0 To 49
                      n_Sub = n
                                Line_Raschet2(NL)    'Let's call the procedure for calculating the segment parameters
                                Lines(NL,n).IsVisible = Line_Visible 'We will apply visibility to the line necessarily - after the calculation
                                If Line_Visible Then
                                                    With     Lines(NL,n)
                                                        .Width = Line_Width
                                                        .Height = L_LineHeight
                                                        .left = Line_Left
                                                        .Top = Line_Top
                                                        .Rotate ( Point_Rotate_X , Point_Rotate_Y, Line_Rotate )
                                                        .StrokeThickness =  L_LineThickness
                                                        .Stroke = L_ColorLine
                                                    End With
                                End If
                    Else
                        Lines(NL,n).IsVisible = False
                    End If
                 Next n
End If
End Sub
